Unread 10-09-06, 08:28 AM
This is a really good question.
Mine had it installed from the factory. I would suppose that if you buy one, it will have the locating holes, and then use them to position your holes for the nuts. Note, however, that it must be fully flush up against the fuselage before you do anything. I can not install mine unless it is jacked up flush.
