Unread 11-04-06, 08:43 AM
TAS (Thin Air Seeker)
hot plate
I didn't find any gold on it but many times I found it to be worth it's weight in gold. I use it quite a lot in Michigan weather.
BTW, I seen hot plates just like it on other types of aircraft. Don't narrow your search for one only to Skymasters! Check to determine what other Cessna aircraft use it. I'm not sure but check the 206, 210, 335, 340 and 414 type. You might find one at a reduced cost.
