T337B Fuel Problem
Has anyone run into this problem:
After 30 min to one hour flight the front eng fuel pressure fluxtuates and if the boost pump is not turned on high for a few seconds the engine will quit. After the pump is run for about 5 seconds and turned off the engine will run normal the rest of the flight. This has happened several times and I have been unable to determine the problem. Any suggestions?
