Paul,
Note also that the light is activated by an air pressure switch, not by the timer itself.
The fact that the light illuminates indicates that the system is pressurized and the pressure is sufficient.
If you have a leak that only occurs when the system is under pressure, you might see the behavior you are seeing.
David
