Unread 03-18-07, 10:06 PM
gfcudahy gfcudahy is offline
gfcudahy is an unknown quantity at this point
Downlock microswitch adjustment
On the later AC the upper screw on the downlock microswitch fits into a small slot on its mounting bracket allowing some adjustment in and out. Probably that way on your AC, but it can not be seen because the switch covers the slot. Both nuts must be loosened with a 3/16" wrench in order to adjust.
George
