A Skymaster is a multi-engined airplane. You must have a mutli engine rating to log the time. There is nothing written about a center line thrust limitation there.
If the aiplane had more than one throttle, the time goes in the many motored column.
The airplane still has the limitations of single engine flight that a conventional multi engined aircraft has except for Vmc issues. And it has procedures unique to the type design too. For instance, in a C-310, if you lose an engine after take off, you clean it up by raising the gear and flaps. You best not do that in a 337.
