Unread 11-08-07, 07:03 PM
I used the one that Larry is describing and I wouldn't give 2 cents for it. If you are worried about wet and ice that unit won't work at all once the tire is wet. The powertow like I have has snow chains and they work pretty good. Once you have the unit on the front wheel you can leverage the weight of the plane to get your traction by pushing down on the tow handles. Works good.
