Unread 12-23-07, 06:51 PM
rmorris rmorris is offline
The crack is very obvious from the outside of the engine, and the low oil pressure (I believe) is caused by the fact that a huge amount of oil came out the crack into the engine compartment.
I found some engines on a site where they were selling them inexpensive as a result of a prop strike. Since I am only looking (I thino) for a case, is it possible to grab a case from another salvage engine and then use all the other components from mine - as opposed to welding my case? If so, can I get the heavier case (assuming one is avail) and still use my components?
Vaporizers
