Alfonso, good luck on RTW.
Flint also makes wing tip tanks for the Skymaster.
I don't have a clue on the costs. You could consider a 55 gallon drum in the cockpit for extra fuel. You'll have to plumb it into the main tanks, with a pump.
If you kept the plumbing parts seperate, you could remove the drum when you didn't need it, and get one when you did.
