Don
I am no better pilot! I think that you are now cleaning out the engine after a length of inactivity and perhaps a lot of carbon buildup. As you are aware you need to run the engines above 180 deg oil temp for one hour minimum to burn off the moisture etc. Those trips to Mexico is what it needs.
GMAS
Sounds like I would be very interested as well. It is a good idea having a couple of filters (in parallel) to avoid this problem.
Like Don, I rarely run less than two hours at any one time with at least 68% power.
Hopefully Don is just about over this problem. I think Skyking finally sorted out the problem as well.
Bob
