Unread 12-01-08, 10:33 PM
JeffAxel JeffAxel is offline
Herb
I noticed on the shot of the ceiling of your plane these big black rectangles glued to the aluminum. I think this is the lead stuff Cessna used for soundproofing. If so, it has resulted in corrosion in some planes. I would rip any of it you see out, and look for corrosion underneath. I bet you will find these in the belly as well, and corrosion is more likely down there. As to the foam insulation, my P337 had it when I got it and I think it helps on the noise front. It really helps with temperature insulation as well. Nice panel!! Hope your interior goes in well....keep us in the loop......we all love seeing other guys spend money!!
