Unread 12-05-08, 04:54 PM
Hydraulic Lines on Mains
Looking at the Hydraulic lines on the main gear and wondering if I should change them while I have this all torn apart. When running my fingers along the braided lines I notice it feels a little like there is hair protruding out of the braiding. Is this rubber? Is this normal or could this be an indication of something?
Also Jeff indicated that I should remove the black patches that are glued to the skin of the interior of the cabin. There were a couple already missing and some corrosion was apparent on the skin where the lead patch was. I removed a couple more but did not find corrosion under them. Some of them seem to be really attached strong and I had a hard time even forcing the putty knife under them. Should I still remove them all? Even if there is no corrosion?
I haven't looked under the floor yet. I assume there are some of these down there too?
Name:	2JF Hydra Lines Main.jpg
ID:	681   Click image for larger version
Name:	2JF Lead Pads.jpg
ID:	682   Click image for larger version
Name:	2JF Ceiling Corrs.jpg
ID:	683   Click image for larger version
Name:	2JF Ceiling No Corrs.jpg
ID:	684   Click image for larger version
Name:	2JF No windows.jpg
