Unread 12-09-08, 07:58 AM
Good advice, it will be done. Where did you source the lines? Has anyone used Precision Hose, PHT, in Tulsa? They indicate that they have a complete kit. I am searching the logs now to see if any hoses have been replaced just as a good exercise. Also checking the Service Manual for requirements, not real clear.
Installing the FM oil filters adaptors, eliminate always cleaning those annoying screens. Also found issues with the rear motor mounts. One is actually cracked and crumbling. New ones on order.
My front engine has plagued me with an oil leak for several years now. Nothing huge but very discouraging. I have looked and looked but haven't been able to really zero in on a obvious source. My AI said that some push rod tubes showed a little wet, could be but I keep thinking there is something on the rear of the front engine that is culprit. What about the alternator? Has anyone had a bad leak around that unit? When I fly 2 - 3 hours and stop I have a couple of small puddles of oil on the front tire and ground. I don't use that much oil in the engine. Maybe 1 - 2 quart for between oil changes (25 hrs). Is that too much? I have 1500 hours on the engine.
Well, I didn't brave the trip yesterday but will be working on it today. I am ordering all the glass today from Great Lakes Aero in Flint, MI. I will be talking to Precision Hose and consulting with Whelen on their LED / strobe position wing tip lights. Has anyone had these installed? Whelen says that I will need to get field approval. It would be a lot easier if I can show another aircraft that has been approved through the FSDO. Even if it is not a Skymaster let me know if you know of anything. This LED technology is amazing. I can't imagine not allowing something like this. It has to be safer (greater visibility for other aircraft), uses a lot less amps, come on get with the program here. Whelen should be more proactive on this.
