Unread 12-20-08, 09:52 PM
I have had the Skymaster 10 yrs now and engine leaks have mostly been the gaskets under the valve covers. At some point they were discovered to be poorly installed and old so I had them all replaced. Leakage has been nearly zero. The new ones did require some retightening a couple of times, probably due for a check agin. Have had some minor leaks of the gaskets you describe but not a problem.
