  #32
Unread 01-02-09, 02:42 PM
You should have that wing supported when those stress plates are removed..I believe that is in the manual. You may tear the skin around the screw holes trying to get them realigned with the nut plates. The wings will droop with those stress plates removed and the wing not shored up.
I usually place a jack under the standard jack point and another outboard of the landing lights using a wood plank and some padding. This will support the wing.
