What you have to remember is that these aircraft are getting old now, you live down in Miami and The Bahamas and the sea air does take its toll on the electrics. The pins and sockets used on the white connector do suffer and do need inspecting, this affects not only the Cessna but all other makes as well. So even unplugging a connector cleaning and reconnecting may cure the problem. I have seen it over here with Aztecs/Navajo and a lot of Cessna 150/152/172 based at sea side airfields.
See you
Cheers
Pete
