Unread 03-19-09, 10:33 AM
rmorris rmorris is offline
Front fuel issue
Interesting issue just started happening, and was wondering if anyone else has seen something similar. Looking for either actual experience, or suggestions based on theory (but please denote which one applies when responding).
Normal start on mr front engine is to engage hi boost pump, wait 7 seconds, engage starter, and after the engine fires off remove the boost pump.
Last few flights it has worked ok for starting, but when I remove the boost pump it dies. I played with some combinations and it now stays 'alive' if I leave in the low boost pump.
Once the engine is warmed up, I can remove the low boost pump and it seems to be fine.
-Robert Morris
rmorris@agsi.us
Starcraft ii replays
