Unread 08-20-02, 07:29 PM
jcthomas jcthomas is offline
jcthomas is an unknown quantity at this point
Angry Turbo Compressor Impeller
I just completed an annual and flew my bird south. After the annual, I lost the boost in the front engine. discovered that the band that holds the compression impeller did not have a nut on the end and it was loose. also discovered that the hose going up to the engine hand two of the four bands loose.
Net result, the compression impeller turned a little off center and caused some very minor scrapes on the blades. Made for a nice day.
Question: Where can I get a new impeller or do I have to buy the whole works?
John
