Thread: Cessna C337 SID
Unread 01-18-10, 10:06 AM
With some minor disassembly of the wing fairings, the attach points are visually accessable, so the borescope is not necessary.
What you won't see are potential cracks emenating from the bolt holes, or corrosion that may be hiding in the bolt holes, or the laminated layers where the outer wing spar mates with the center section carry thru.
Way back in the dark ages when I worked as a quality assurance engineer the team was constantly coming up with ways to perform NDE on new assemblies that were being designed as the plant was being built. It seems that 30 years latter there can be a creative examination designed for this application if it comes to that.
