Thread: Cessna C337 SID
Unread 01-19-10, 09:10 AM
tropical tropical is offline
Either way, it is my understanding that under the old way of aircraft certification (CARs) the only thing mandatory are AD's. And that the maintenance manual published at the time the aircraft was built is the only other authority for required maintenance (other than the 100hr/annual)...periodic updates to the maintenance manual is informational only, if you chose to ignore them.
Not really. It's up to the person that is signing the inspection to make the determination.
Put yourself in the mechanics position, you sign off an annual inspection and decide to ignore to MM and recommended inspections. The airplane is in an accident and the first thing the attorneys want are the log books. They now find the mechanic ignored "factory recommended" inspections. See where this is going?
I think a lot of shops will be reluctant to sign off these planes without complying with the inspections.
