re oil level
Guys
There is a much easier method to determine oil level.
When you wipe down the aircraft figure out how much came off on the rags. If is close to 1/2 qt then add a full qt to be on the safe side.
Little harder on the rear engine. You put a bucket under the drain and when you come to fly it next time multiply the amount collected by 4 and add that amount to the engine.
must be more accurate and scientific.
bob
