Both Windows
I don't have the lower rear window in front of the door. You can install it by using the O2A parts, and again have it signed off by your mechanic as installed per O2A service manual. However, this would require removing the front panels, installing the proper ribs/bulkheads, and then putting in the windows.
As far as purchasing an O2A door, I found a O2A being parted, and bought it for $400. However, you can call Don Meisser at Commodore Aerospace. I am sure he either has one or can locate one for you.
Thanks!
Mike
