Unread 02-06-12, 11:02 PM
Battery
Hi Tracy
A battery not up to par will do some strange things on a skymaster. Before you go wild checking out everything, A new battery is the best thing to do since in general, they should be replaced more often than you think. On average, I get about 18 months of useful battery performance then I get a new one to avoid things you are experiencing.
The voltage reg could be checked out very quickly. Just keep one alt off line. If the problem continues when you test each that way, then it is not the volt. Reg.
I suggest a new battery
Good luck
Jerry
BTL
