Unread 05-14-12, 12:27 PM
I see only 3 part numbers in the 1965 IPC figure and parts table (relevant parts shown below). Note that in the table the penultimate column is "units per assy" and it shows 2 inboard actuator cables (item 8), 2 outboard actuator cables (item 9) and one return cable (item 27). This is confusing to me, because I interpret "assy" to mean wing and I only see one of each actuator cable per wing. And if "assy" means "aircraft", I'm still confused because it looks as if each wing has its own return cable, so 2 should be listed per aircraft (not one), unless the return cable is super-long and reaches out to both wings. Anyhow, if you're working in this area, the number of cables should be evident.
Name:	65-337 flaps.jpg
