Unread 12-11-12, 05:07 PM
Originally Posted by mhudsonbsme View Post
TCM emailed this to me and I would like to share it with the group. It is SID97-3E dated 6/17/08. It is the instructions on how to adjust the TCM fuel injection systems.
It's an excellent Service INFORMATION Directive. It is not REGULATORY, so you can set the engine up as per the SID, then add FF until the Target EGT is correct. We have found that the best operational set-up is to set the unmetered LOW pressure at the bottom of the range and the HIGH pressure at the top of the range, then tweak the max FF up. This results in good mixture at low powers and adequate FF to keep CHTs and ICPs under control at high power settings.
Walter Atkinson
Advanced Pilot Seminars
