Unread 10-14-13, 11:21 AM
N456TL
A couple of suggestions I suppose:
1) Have you Maintenance firm generate a Form 337 to lower the MTOW on your aircraft.
2) Send them a copy of that 337 minor modification form to Euro Control.
3) You could call the New York FISDO who look after Europe and have a general discussion with them as they may have an alternate and better way of doing the same thing.
4) If that doesn't work, talk to one of the DER's on the forum and ask them to write up a major mod and fill that in and submit that.
On the Form 337 - Minor Modifications form, I'm not even sure you would need to, but sending it to the FAA then registers the lowering of MTOW on the FAA's aircraft file should Euro Control ever want to check. Check with the New York FISDO.
