Thread: Shimmy Dampener
Unread 12-10-13, 10:54 PM
SkyMac's Avatar
SkyMac SkyMac is offline
Unhappy Shimmy Dampener
Hi Everyone
During refurbishment of the nose gear and wheel bay I removed the shimmy dampener, only to find the rear mount has a crack in it.
On the bright side the nose gear rebuild and wheel bay are done. Whilst in this area I also took the opportunity to overhaul the aux fuel pump and rebuild the fuel strainer, removed cleaned and checked all hydraulic lines as well as replaced all terminals on the wiring, still trying to locate that black rubber boot which covers the terminal block in the wheel well.
My question to the group is: Does anyone have a shimmy dampener housing, as I will reuse my internals with a new seal kit. And from what I can see Lord do not make a direct replacement.
PN:1442114-7 Shimmy Dampener
or
Housing 1442112-496 as moulded into the side of the housing.
I have asked Don, but yet to hear back from him.
