"re gear light, not sure re all Cessna models but in my R182 and 337 this is a push to test feature which like many of the panel lights will light or sound when pushed regardless of the status of the system (unless the light or horn has failed)."
James - On your R182, try the push to test with the throttle pushed in or better yet, push the green gear light while at the same time pushing the throttle in, the gear horn will stop when the switch is tripped.
This does not seem to be the case on the 337 I'm working on and I'm trying to establish if it is normal and in that case, different than other Cessna gear warning schemas.
