Unread 08-09-14, 07:41 PM
hew's Avatar
hew hew is offline
Gear doors issue SOLVED
If you have problems with the gear doors as per my previous thread I have solved the problem. Step one, replace both up-lock switches. No more steps!
I replaced one switch which made to problem intermittent, once I had replaced both switches I have had no more problems. The red herring in this issue was that the system worked perfectly well during retract tests and the switches checked out when tested and operated manually. For some reason, vibration in the air was preventing them contacting reliably. Without a complete electrical circuit around all the up-lock switches the doors won't close. At $70 each it's a very cheap fix before you go looking for other problems.
