Unread 10-03-02, 09:32 AM
Dale Campbell's Avatar
Smile Gear up problem
I agree with all GMAS & the other say with the precautions. The best way to really test things is on the jacks. Use the power pack to move the gear because I also think the power pack motor is your problem. As far as doing damage to system, remember the system turns off when the pressure reaches 1400 PSI with the switch on top of pump. Thats what hold pressure on gear when gear is all the way up or down, even though the locks are in. I to have had a lot of problem with gear, both going up & down.
