Aileron rod assy actuating rod part number
Hello Herb,
Thank you for your help. The part number is 1462001-5
This is the part number for the entire assembly including the tube and rod ends.
Thank you so much.
Chris
P.S. spoke with cessna and the threaded end is made from 4130 steel round bar stock with an original diameter of .437 This stock is then shaped so that half of the rod is smooth and slides into the actuating tube and the other half is threaded. Could have one made if need be because the rest of the assembly is perfect.
