Thread: exhaust-ing
Unread 07-09-15, 10:40 AM
JamesC JamesC is offline
Just eyeballing the set up – does it fit better if you rotate the collector 180° about the vertical axis and reinstall it? If the exhaust is fresh you should be able to easily rotate all the slip fittings to adjust/adapt angles slightly…
