I read this and went Wow! New Fuel Type!
Paul, it is my experience that just a little water will make an engine run rough (drops), 7 gallons a side would kill them dead. I'm wondering if when you drained the tanks it actually separated or if there was lighting or other characteristic's such as lack of or breakdown of dye that caused you to believe it was water? I also own a 73P, if there are no fuel stains on the upper wing skins after you fuel it, there is no leak. The way they overlay would prevent water entry. Welcome to the club, Best of luck with your new Skymaster!
Brent
