Bob
Yep I don't think we are going to get a reply from this guy, any here are the conection for the + & - 6 volts, measured on the either the roll or pitch servo connector.
Pin L + 6 volts +_ 1%
Pin C - 6 volts +- 1%
Pin H + 28 volts switched
All the voltages to be measured ref to ground and with the autopilot switch engaged or held on.
If these are ok them something is wrong with the remote disengage switch on the control column.
Let me know how you get on
Pete Somers
