Rear engine
rmorris,
About a month ago, you were also having an issue with the rear prop feathering, and you had the governor worked on. Is there any thoughts you have had to see if the two issues were connected - maybe debris was already in the oil and causing governor problems? They may be completely unrelated - I guess I am just always looking to see if there are early detectors of issues.
