TC:
Congratulations on getting your Multi rating and on the purchase of your 337! You will enjoy flying it.
Re- 1. 450 on the CHT is on the high side. If the others cylinders are lower, and the fuel flow adjustment -to get max fuel on takeoff- is good, then I would look at the injector for that cylinder and also the baffling.
Re- 2 Rigging of the throttle should be looked at. Are you getting max fuel flow on takeoff?
Richard
