Unread 11-15-17, 01:59 PM
There are no switches on the doors so one of the down lock switches is not closing. Check with an OHM meter each switch, one on each of the main gear and one on the nose. If those check ok then you have a bad wire. The wires are in series and must make the circuit. Visually check each wire connection and terminal end.
