Unread 11-28-17, 07:11 PM
pilotpat pilotpat is offline
pilotpat is on a distinguished road
Jeff, in the end we did not go ahead with G4 install but will at some time. The recommendation was to replace the hose going to the flow distributor with two shorter pieces and have the fuel flow sensor in the middle mounted inline "floating" with the hose which is properly secured by the installer, who hopefully has done such installs before. We also had difficulty figuring out where to connect the oil temperature sensor, which cannot replace the existing unit because the G4 is not a primary instrument aside from CHT/EGT. The avionics shop we talked to (BrantAero at CYFD) had a location they had used before, as the alternates suggested by Insight were blocked by the governor unit or did not exist on our engine.
Pat
