Thanks for responding:
Ernie, I have made contact with Luis, hope to see you guys soon.
Sky-King to answer questions this has not instantly developed after service, first noticed 20 hrs into reservoir fill-up (intermitent).
Bob-- actuators are not leaking (externally!). After replacing hoses all panels were removed cleaned and inspected (nothing) wet belly is from reservoir overflow. My concern is a pump sucking air?? causing some sort of foaming? Or are actuators in need of re-build. Both scenarios could be expensive and un-necessary. Are these items field serviceable?? Proper (type specific!) Diagnosis is worth everything. Which I realize is one of the core values of our group.
Thanks again... Mel
