Unread 12-20-17, 08:30 PM
cessnadriver's Avatar
Smile Some electrical equipment on WITHOUT the master switch ON?
JAG. Thanks for the reply. My 1965 C337 is SN: 0200. I can get a picture of the solenoid BUT I've already removed the wires from the bottom posts? If you check the BATTERY CIRCUIT and/or Charging system schematics for SNs 001- 0525 they're the same. Cessna changed the part number and type of the solenoid, ie, from S1578 ( SNs 0235-0525 I think) to a newer PN is S-1580-1 which has been superseded several times since (But they are basically the same type). My worries are that moving the "generator" wire to a fuse from the Positive side of the solenoid to the load side may affect the RUN/STAND-BY switch? LET ME KNOW IF YOU STILL WANT THE PICTURE??
BILLS
