Unread 10-19-02, 02:19 AM
GMAs GMAs is offline
George M. Amthor, Jr.
Post yes their is one to install two batteries...
The last time I checked you could do like the military does.. and have two batteries.. one out where it is.. and another inside at the rear of the cabin... nice place to have one... works well on fabric stuff...
Otherwise .. its keep the battery where it is and in good shape... after all after the engine is started... you should have enough electrical power that the battery is not doing much anymore... its only their to start the plane... and then act like a big capacator to filter out the voltage spikes and ripples...
If you need more electrical power to start... they put that little plug on the outside lower left cowling... to hook up to a battery cart... or GPU... which can be made up of two car batteries or a 100 amp plus 28 volt engine driven unit... and please read the POH first before hooking it up... as its not like just another battery if you do... things will come on without the master being on... and it could kick the starter in also...when hooked up.... so stay away from the props.... G.M>GMAs
