Thread: over-voltage
Unread 02-26-18, 03:38 PM
kilr4d's Avatar
kilr4d kilr4d is offline
The diode looks like a cylinder maybe an inch long and having a diameter of about a half an inch. The thing was enclosed inside a plastic case. There is a small metal pole protruding from this cylinder that a wire attaches to. Now for all I know the diode is encased inside this cylinder or maybe the entire cylinder is the diode. I have no clue how all this stuff works. That's why I pay these guys. Well, the little metal pole that is protruding from the cylinder was loose. You could actually wiggle it around inside the cylinder. Comparing it to the other diode on the firewall, that one was very tight. No play whatsoever. Replacing that $8.00 diode seems to have solved the problem. Voltage across the system running on a either single or both alternators is rock solid at 28.5 volts plus/minus 0.1 volts and no over-voltage tripping has yet to occur. Granted, I haven't flown much yet since the repair but so far so good. It's been a long winter. Better Wx ahead. Stay tuned.
Interesting.
Could you grab a picture the next time you have the cowl off?
John
_________
John K
1977 337G
CNC3
