Interconnected elevator trim to flaps
Hello all.
During a pre-flight I noticed my elevator trim does NOT automatically roll forward while bring up the flaps with the trim wheel rolled full down position. I went through the manual re-adjusted the fitting that is suppose to bump against the elevator trim stops. Afterwards I re checked to see if the trim wheel moved forward as required. It did one time. After that the trim did not move as it should. Has anyone else had this problem?
Thanks in advance.
Regards.
BILLS
Reason: grammar
