Brake performance question?
Hello. I have a very tried '65 C337 with organic pads and have no problems with holding full power with the brakes, but I do have a mechanical brake handle NOT the hydraulic that you may have. If so you might want your mechanic to check the parking brake "HOLDING" valve for a leak or worn 'O' rings in the valve!
Hope this helps.
Regards, BILLS A&P
