Unread 04-02-19, 09:30 AM
Dr.Dave,
Thanks for the tip on the Master Avionics Breaker and Switch...Had not thought about that. With building a new CB panel, I like the ability to isolate certain things.
Yes, the studs on the starter are 3/8". I went ahead also and bought a large stock of terminals, wire and a good crimper that goes up to 4 AWG. Even though I have 30 amp alternators on my bird, I am going to upgrade the wiring from the alternators and the shunts. Since I have the aircraft completely opened up and changing throttle/prop cables on the rear engine, it is so easy to run new wires.
