Unread 07-23-19, 01:15 PM
B2C2 B2C2 is offline
I am also interested in working on the windows on my 1969 T337D. The outer windows seem pretty good, but I have some crazing on the inner pilots side window and there is a leak between the inner and outer windows in a few spots so there are streaks in there from the occasional outdoor rainstorm the plane gets (its usually hangared) dragging dirt into that space. What is the seal arrangement between the inner and outer windows and can this be repaired by just removing the inner windows? Also can you confirm that its a simple matter to remove the inner windows, maybe post some pictures of the inner trim removed. I am thinking of replacing the inner windows and replacing the seals at the same time for my next annual "while your at it" expense.
