The light turns on and stays on even after the doors fall open, when you ground open the doors, all 4(I have the gear door deleted kit), you can halfway close the front gear doors By hand BUT NOT THE 2 REAR DOORS. Something to do with the front actuating cylinder is causing the hold up pressure to bleed off.
Secondly if I resort to pulling the power pack, who’s best for the job?
