Unread 11-23-19, 03:30 AM
excellent to hear problem solved
so sorry about wife, hope she's better
if it makes you feel better....similarly had fuel pump leak issue and also filter drain issue with dripping boost pump to boot. I figured if seals wore out in fuel pump/filter/boost pump, other rubber in fuel system likely at end of life. So I replaced throttle control and fuel flow divider, various o-rings, fuel cap seal, all flexible fuel line hoses.
Got my fuel system education
All to say, don't feel bad about replacing what may not have directly related to drip. Those fuel system parts were likely near the end of their service life as are others you have not yet replaced.
