Unread 01-08-20, 07:36 AM
Hp and Gem
Kevin,
I did it old school. The issue is getting the PCMCIA card to interface to your computer. Almost impossible. So I change the media. I purchased a PCMCIA to PC Card adaptor,about 15 dollars. Then I found a 64MB PC Card. BTW. This was tricky. Need to be old enough to work with HP and new enough to be read by newer windows computer. I also puchased a multi format card reader, one that can read a PC Card. From there it was pretty easy. You put gemcom.com on the card and run it from there. You have plenty of available space for files. To transfer files to computer, remove the card from HP and read directly on the windows computer. The ASC files created in the expand mode are then imported as CSV into Excel. Start at row 18 and note that the data includes headers. You are welcome to call me if you want. 917-648-3839
