Unread 08-01-20, 09:01 AM
Cooling
Herb is correct about AD modification. The cooling air from the ports on side of fuselage cools your avionics, And on left side there should be a small ‘y’ that takes air from that cooling line and takes air up to gauges. I have installed an instrument cooling fan and run a dedicated hose just to those engine gauges.
